I'm planning to design a pcb for the Chua oscillator, a circuit which I have been interested in for a while. I'm completely new at this and I don't know much about electronics so before I go off to get parts and design the layout, I have a few questions about what components to use.
-Under operation the circuit would be intended to be hooked up to power and an oscilloscope, the user would turn some knobs, and observe the results. For the oscilloscope hookup, should I use a BNC connector, or just some pin headers for probes to hook onto?
-One of the voltages I'd like to measure is the floating voltage across a resistor. I'm planning to use an instrumentation amp IC to get this voltage, but if I just took the inputs across the resistor, I'd have to run a very low gain(<10 by voltage) to prevent the output from clipping. There is a considerable amount of common-mode signal(2-3 times the differential, voltage-wise) here, though, and from browsing relevant component datasheets(including the one I've settled on for now, INA217), CMRR seems to improve with higher gain. Should I divide the voltage across the resistor so I can use a higher gain, or just settle for the low gain CMRR?
