Author Topic: Speed controller issues  (Read 276 times)
Offline adiorio110Topic starter
« on: January 11, 2025, 10:20:29 pm »
Hi All
I sure one of you guys can figure this out.
I have a motor I want go clockwise for 10 seconds stop for 3 seconds and go counterclockwise for 10 secs and repeat several times. I got that to work fine with forward reverse motor controller.
Problem is the motor is 3000rpm I want to be able to lower and control speed.
The speed control also works fine independent from the motor controller (Only test in one direction)
12V 3000rpm motor cw/ccw
https://www.amazon.com/gp/product/B07ZNX5MK3/ref=ewc_pr_img_5?smid=A142RLYNPQ7MGH&psc=1
5V - 24V Motor Controller Motor Forward/Reverse Controller Timing Delay Time Cycles Relay Motor Controller Board with LED (https://www.amazon.com/dp/B07S1B4H1Q?ref=ppx_yo2ov_dt_b_fed_asin_title)
When I wire in the Speed controller with the motor controller it only works in forward direction
it will spin forward 10s stop 3s next ten secs will pulse the motor but will not spin then it will again go forward for 10s
I will enclose pictures of what I have
Thank You
Anthony
« Last Edit: January 11, 2025, 10:23:50 pm by adiorio110 »
Offline BeBuLamar
Re: Speed controller issues
« Reply #1 on: January 11, 2025, 11:54:31 pm »
Do you have information on your motor controller?
« Reply #2 on: January 12, 2025, 12:50:30 am »
Sorry it did not come with instructions
Just have youtube video on setting up
https://youtu.be/Y1gwOkPtqCg?si=jhfkpFysh7cmBelZ
« Reply #3 on: January 12, 2025, 05:34:40 am »
I just figured what may be a solution.. If I use a power supply that I can regulate voltage  I can make it work as I need...
Will this cause a problem ?
