Author Topic: 555 discharge pin  (Read 1216 times)
Offline ChaiTopic starter
555 discharge pin
« on: March 17, 2016, 04:51:47 am »
I'm confused why a LOW on the output pin 3 would drive the discharge pin 7 to ground. I thought a low coming from the flipflop/output connected to the base of an NPN would turn off the transistor and disconnect pin 7 from ground. What am I missing here?  :-//
Discharge, The discharge pin is connected directly to the Collector of an internal NPN transistor which is used to “discharge” the timing capacitor to ground when the output at pin 3 switches “LOW”.
http://www.electronics-tutorials.ws/waveforms/555_timer.html
Offline LukeW
Re: 555 discharge pin
« Reply #1 on: March 17, 2016, 06:18:19 am »
The output driver section is inverting.
« Reply #2 on: March 17, 2016, 06:42:06 am »
Hah! Thanks :-+
