Soooo, if I'm understinding, I should use flux then?
Figured it'd be something like that. I hoped the positive reviews for it were legit, guess not. I'll buy better braid.
As far as flux, since I need to buy some of that too, any brand recommendations? I know not to use plumbing flux.
Regarding the soldering iron, I tried 2 tips (the parts I was desoldering were fairly small) a point and a small spade (I think that's what they're called) basically a standard conical tip (goes down to about 1mm) and the smallest flat tip I had (about 1.5mm 2mm maybe?).
Iron started at 340 C, took it up to 360C. Solder was melting well so didn't want to take it too high.
Pretty sure I cooked several components while practicing, but that's why I'm practicing on junk.
