Author Topic: Square wave DC vs AC coupling  (Read 6377 times)
Offline hgg
  • Country: gr
« on: May 05, 2016, 10:56:16 am »
Hi.
I am using a cheap ebay signal generator to display a 1Vpk 1Khz square wave to my oscilloscope.
When the scope is in DC coupling the signal goes from +500mV to -500mV from 10% to 90% duty
cycle and its vertically centered.
I then change the scope to AC coupling and when the duty cycle is less or greater than 50% the
signal is offset positive or negative on the display.  Shouldn't the signal remain vertically centered
despite the changing duty cycle?
Is this normal ?
Thanks.
Re: Square wave DC vs AC coupling
« Reply #1 on: May 05, 2016, 11:06:58 am »
No it doesn't look right.  :o
Could Trigger level settings have something to do with it?
They're hidden by the measure menu.
Can you re-check trigger levels for AC coupling?
tautech rushes off to get a SDS1102 to check for himself.......  :popcorn:
Avid Rabid Hobbyist
Offline hgg
  • Country: gr
« Reply #2 on: May 05, 2016, 11:11:43 am »
Hmmm.
Triggering is set to rising edge/auto and the vertical centering does not change
with different trigger levels.  Only the horizontal centering.
Could that be a problem with the signal gen?
Offline JPortici
« Reply #3 on: May 05, 2016, 11:14:32 am »
why am i not surprised by this? what am i missing?
Offline Zero999
  • 0999
« Reply #4 on: May 05, 2016, 11:20:09 am »
Hi.
Is this normal ?
Thanks.
Yes it's perfectly normal and to be expected.
When AC coupled the DC bias will change as the capacitor charges/discharges due to the net DC in the signal. Try setting the 'scope to DC coupled and connect a 1nF capacitor in series with the probe and signal generator.
The following users thanked this post: hgg
Offline hgg
  • Country: gr
« Reply #5 on: May 05, 2016, 11:29:49 am »
Confused...
I just did what Hero999 suggested and when I connect a 1pF capacitor in line with the signal
and with DC coupling, I get the same result.
So, is it normal or my AC coupling has a problem  ???   (a posting was just deleted?  eevblog ghosts)
« Last Edit: May 05, 2016, 11:31:53 am by hgg »
Offline hgg
  • Country: gr
« Reply #6 on: May 05, 2016, 11:36:07 am »
Is this the oscilloscope's AC coupling capacitor?
Can this be solved or is it observed in all oscilloscopes?
« Reply #7 on: May 05, 2016, 11:38:49 am »
Here's 1KHz 1V p-p from a SDG1010, BNC fed (1:1) AC coupled into a brand new SDS1102CML triggering and displayed on Ch 1. Trigger level moved slightly to be visible.  ;)
Same as yours
Based on Hero's comments it does seem normal based on 50% DC :o
Obviously basic stuff that I've never encountered before.  :palm:
Off to check with another.....  :scared:  :-DD
« Last Edit: May 05, 2016, 12:15:09 pm by tautech »
Avid Rabid Hobbyist
Offline JPortici
« Reply #8 on: May 05, 2016, 11:39:13 am »
when you high-pass filter or AC-couple a waveform you remove the DC component of the signal and something above it until the cutoff frequency.
This is a periodic waveform so the DC value is its mean value (which in the case of a pulse wave it depends also on the duty cycle).
high pass filter -> the mean value is zero -> the waveform can no longer be centered around +/- .5V or its mean value wouldn't be zero.
this is not a problem, it's math, it's how the universe works.
« Last Edit: May 05, 2016, 11:41:54 am by JPortici »
Offline Zero999
  • 0999
« Reply #9 on: May 05, 2016, 11:43:09 am »
Confused...
Well 1pF may be a bit too small.
When the duty cycle is nearly 100%, the AC coupling capacitor charges up to 1V and it's in series with the 'scope input so you see the signal, -1V.
When the duty cycle is near 0%, the AC coupling capacitor charges to -1V so you see the signal +1V.
It's perfectly normal and can be seen in any AC coupled signal.
Offline hgg
  • Country: gr
« Reply #10 on: May 05, 2016, 11:47:17 am »
You are right.
Can the scope display this offset as a live parameter?
Offline hgg
  • Country: gr
« Reply #11 on: May 05, 2016, 11:58:20 am »
Correction:
"I just did what Hero999 suggested and when I connect a 1pF capacitor in line with the signal
with the AC coupling"
Offline hgg
  • Country: gr
« Reply #12 on: May 05, 2016, 12:11:43 pm »
I can measure the DC offset with the multimeter, which shows -478mV when at %1 and +478mV when at %99
duty cycle.
I was wondering if there is a way to display the same offset on the scope.
Offline hgg
  • Country: gr
« Reply #13 on: May 05, 2016, 12:29:20 pm »
I searched the Siglent SDS1102CML and I could not find any built in parameter to show that offset.
Anyway, I've just upgraded to the latest firmware and I was looking for changes.
Thanks for the help!
George.
Offline Zero999
  • 0999
« Reply #14 on: May 05, 2016, 12:36:02 pm »
I doubt you'll be able to find an oscilloscope which can measure the DC offset because the AC coupling capacitor is before the ADC.
The easiest way is to just use a multimeter.
Offline macboy
« Reply #15 on: May 05, 2016, 12:49:37 pm »
The signal is no longer centered because it is no longer symmetric. The AC coupling doesn't somehow look at peak voltages and choose a position based on them. It is much simpler, it removes the DC component. A square wave with amplitude of +/- 1 V (i.e. 2 Vpp) with 80% duty cycle has a DC component of 0.6 V. Imagine adding an offset of -0.6 V to that square wave and it will appear exactly in the same position as when you AC couple. Another intuitive way to think about it is that using AC coupling ensures that the area under the waveform is equal for positive and for negative portions of the waveform, illustrated like:
Online PA0PBZ
« Reply #16 on: May 05, 2016, 12:50:14 pm »
First I was thinking the same but since the scope knows the capacitor value, the frequency and the duty cycle (waveform), I wonder if it could calculate the offset.
No doubt about that.
« Reply #17 on: May 05, 2016, 12:52:15 pm »
My screenshots were with the latest FW.....forgot to mention that.  :-[
Avid Rabid Hobbyist
Offline macboy
« Reply #18 on: May 05, 2016, 12:57:30 pm »
duty cycle.
Display average voltage, with DC coupled input.
Offline hgg
  • Country: gr
« Reply #19 on: May 05, 2016, 01:04:40 pm »
Yep, you are right!  Thanks.
Offline Zero999
  • 0999
« Reply #20 on: May 05, 2016, 01:11:28 pm »
duty cycle.
Yes, that will work but there is no way to get both simultaneously, without using two channels to monitor the same signal.
Offline dmills
« Reply #21 on: May 05, 2016, 02:08:37 pm »
An interesting observation is that over a cycle and once things have settled down, you will find that the area under the trace where the trace is above zero is equal to the area under (over!) the trace when the trace is below zero!
this is because the integral of voltage over a cycle is equal to the DC level, and your AC coupling removes the DC, so the areas above and below the line must become equal.
This is entirely to be expected, and has been the case for AC coupled circuits since the things were invented.
Regards, Dan.
Offline alsetalokin4017
« Reply #22 on: May 06, 2016, 04:38:41 am »
Regards, Dan.
Exactly. Another way of looking at it is that the AC-coupling setting moves the _average_ value of the signal up (or down) to the channel's baseline (0 voltage) reference level.
« Reply #23 on: May 06, 2016, 04:51:56 am »
Confused...
Actually Hero suggested using a 1 nF capacitor, a thousand times more capacitance than your 1 pF cap. Since the probe's capacitance all by itself is likely in the 30 pF range... I am suspecting a typo in your capacitor value.
Even 1 nF is probably smaller than the actual AC-coupling capacitor in your scope. One scope (analog) that I can easily get to uses 22 nF, another (digital) uses 47 nF.
Your AC coupling is doing exactly what it is supposed to do.
(I think confusion over the use and function of AC and DC coupling is probably the most misunderstood aspect of basic scoposcopy. So don't feel too badly, every scope user probably goes through this stage in the beginning.)
Offline hgg
  • Country: gr
« Reply #24 on: May 06, 2016, 04:55:56 am »
Indeed, 1pF was a typo...
Offline vk6zgo
« Reply #25 on: May 06, 2016, 09:25:32 am »
Hi.
Is this normal ?
Thanks.
Some generators produce square waves which are not symmetrical around zero volts,
The signal from these will approximate to zero volts on one half cycle,so you will see  one half cycle at (near as dammit) zero volts,& the other half cycle elevated to + or - whatever voltage is set by the generator controls..
Go to AC coupling,& the square wave will be displayed symmetrically about zero volts.
If you now change the duty cycle of the signal,(incidentally,it is then no longer a square wave,it is a "rectangular wave"),the signal distribution above & below zero volts will change------this is normal.
This case is fairly straight forward,but many generators produce a square wave symmetrical about zero volts.
In this case,the same thing happens with AC coupling as before,but it can be a bit more difficult to discern.
It is exactly the same process---the AC coupling circuit doesn't really care!
