Author Topic: Triangle wave generator  (Read 15529 times)
Offline pkplex
Re: Triangle wave generator
« Reply #25 on: December 10, 2015, 11:14:41 am »
Current circuit, with a 1nF cap it works from around 20Khz to around 400Khz without rounding the triangle waveform. Much fun :)
Thanks w2aew :)
Offline Zero999
  • 0999
« Reply #26 on: December 11, 2015, 01:05:27 pm »
The LM358 makes a rubbish comparator/Schmitt trigger.
If board space is an issue, the 555 timer could be used but note the higher power consumption and the possible need for extra decoupling capacitors, unless a CMOS variant is used.
Offline Yansi
  • STM32, STM8, AVR, 8051
« Reply #27 on: December 13, 2015, 04:19:18 pm »
Whats the advantage of this circuit using separate current sources and the switchbridge?
Same results (or nearly similar) can be obtained with the learn-book basic two opamp triangle wave circuit, if you just replace the integrator's input resistor with potentiometer: wiper on comp. output  and ends through diodes to the opamp input.  Or if you want to set the rising/falling slopes separately, then two pots and again two diodes. Simple, easy, working too.
But sure, the diode switch bridge and current source/sink is more entertaining for a beginner. The biggest disadvantage being the nonlinear current setpoint by the trimpots in the emitors. And note there's an error in the PDF from W2AEW on page 4: misslabeled outputs.
Offline Jay_Diddy_B
« Reply #28 on: December 13, 2015, 05:12:43 pm »
The original schematic is not too far off.
It will work if a faster op-amp is used. It needs at least 3 MHz of GBW and 10V/us of slew rate. The TL084 etc will work.
I also had to adjust the values, but I ended up with 2.5V p-p at 7.5kHz
Regards,
Jay_Diddy_B
Offline w2aew
    • My YouTube Channel
« Reply #29 on: December 13, 2015, 10:26:13 pm »
<snip>
Where's the error in my pdf?
FAE for Tektronix
Offline Yansi
« Reply #30 on: December 14, 2015, 07:24:55 pm »
I apologize, my fault. I have looked again, no problem. Maybe I was too tired and sleepy  when I checked last time.
By the way, you have a great YouTube channel, good source of inspiration.  :-+
Offline w2aew
« Reply #31 on: December 14, 2015, 09:30:49 pm »
Thank you.  I do my best to keep errors out of my videos and support materials, but sometimes they do slip by - so I am happy to hear when someone finds a problem so that I can go back an fix it.
FAE for Tektronix
