Hi Guys,
Q1). Anybody know any good sites for researching SSD Data recovery ?
Q2). Anybody know if the controller's can read any NAND Memory chip (My 500GB Chip is labeled TSEF04TP3FL5K1 02145 looks like TBGA 261 pads) so I can just swap it out with a doner controller chip ?
or is this all a waste of time because the controller chip contains the NAND Data data map tables / the encryption key changes between chip versions so the data is good as lost !
Q3). I seem to struggle to find anything other than high level technical details of the chip and nothing about its firmware, if it can be flashed and how to programm it so I take it this is all propriatory and not publically availiable to non commercial partners ?
Normally its reccomended to move the NAND to a doner board in case a component blew the controller, rather than put the controller doner in the original board.
But in this case im sure its the controller and its a difference between reballing a 144 pad controller chip vs a 261 pad NAND Chip for a beginner.
### Background ###
I have a SATA SSD (Intergral V Series 500GB) that suddenly stopped being detected by the PC BIOS and therfore OS.
I thought this would be a good introduction into BGA reballing and SMD Electronics so I bought myself a Amscope, reballing kit and a hot plate.
I have buzzed out all the caps and resisters and they all look good.
Under a Thernal Imager and I can see no shorts and only the Controller is running hot (30C).
It all suggests that the controller is what has failed
The controller is a
SM2259XT2G AA
TF5B31 00
CH 2H
I have been trying to source a donor SSD board which will turn up in a few days.
I found a mSATA Board with a simlar controller.
SM2259XT G AB
PRPU20.00
TW 4D
I hope the soon to be delivered SSD Doner is teh same revision and has an identical controller.
Others I have purchased say they are the same drive but turn out to be different controllers with 4 NAND Chips not he single one I have.
