Hi, I'm trying to understand a schematic that I found online. The author managed to get a +26.5V to -26.5V swing using three DC-DC converters. Two RO-0524S (
https://www.digikey.ca/en/products/detail/recom-power/RO-0524S/2314954) are used to generate +-24V and a similar ROL-0505S is for a 5V, and connecting them in series gives the desired voltages. The input voltage of these three converters are all 5V.
Please find the attached schematic. Also I think the 27.5V in the schematic is a typo.
My questions are:
1. Why are the outputs of U42, the middle converter, +2.5V and -2.5V. not +5 and 0? Is it because the circuit is symmetric?
2. Is it true that this voltage swing is achievable because the outputs of these three converters are isolated from the input 5V and GND?
3. If question 2 is true, does it mean that this is not achievable by replacing with switch-mode boost converters?
Thank you.
