Hello,
ContextI'm looking to change some of my lightning fixtures in my home.
The general trend seems to be towards integrated LED light fixtures rather than LED bulbs which I'm not thrilled to see but I reckon each has their pros and cons.
Now I read many times that underdriving LEDs results in a better efficiency (lumens/watts) + a much longer life since there is less heat and deterioration of LEDs.
Is that correct?
Anyway I'm thinking to buy powerful lights but dim them.
Note: I do have 2 LED panels controlled by a dedicated LED dimmer module in the wall in one room and it is most of the time set to the minimum (uses 18W for a lot of light - but I have no lux meter to give lumens/watts numbers).
I do NOT need some fancy/design light fixtures and I'd rather avoid some cheap lights on amazon.
I do NOT need remote controls, NO dimmer module in the wall and especially NO smart/connected stuff.
I figured why not buy some LED panels + drivers from reputable brands instead.
In case the panel OR driver fails, I can replace just that component.
LED panels also have the advantage that the form factor is standard (30x30, 60x60, 30x120, etc) so if in worst case it has to be replaced entirely, I could just slide the old panel out from the surface mount, and put a new one (and keep the driver if this is the same panel).
Also LED panels seem to have the best quality/price ratio (I'm assuming because they are produced in large quantities).
QuestionNow my issue is that many LED panels are sold with a non-dimmable driver.
What is the best way to make those dimmable?
Example:
This LED panel:
https://www.lampdirect.be/fr/noxion-panneau-led-delta-pro-v3-0-30w-4070lm-840-blanc-froid-120x30cm-ugr-19-philips-xitanium-driver-equivalent-2x36w-8719157032377Is sold with this Philips "Xitanium" driver:
https://www.docs.lighting.philips.com/en_gb/oem/download/indoor-point/xitanium-single-current/Xitanium_36W_0.7-0.85A_42V_DS_I_230V_929002809006.pdf1. What is the easiest way to to dim this panel? I will dim it during installation (via dip switches or potentiometer as part or placed next to the driver) and never touch it again.
2. Do I need a dimmable led driver? How can I find the right driver from Meanwell (for example):
https://www.meanwell-web.com/en-gb/led-drivers/3. I see most drivers come with 0-10v dimming. What does that mean? can I use a simple potentiometer and connect that to dim- and dim+? or do I need to give it 0-10v? If so are such 0-10v modules sold besides the ones put as switches in the wall?
Thank you
