Thank you All for your responses,
After your inputs I realized I needed to go deep into the books and internet (Wikipedia, ti buck controller ds, etc) as suggested...
I have been reading, not continuously, for about 20 hrs about this topic and yes, it's very extensive and finally I am just starting to understand some of the concepts and how they are related to each other... Specially how phase has a big impact in the voltage and currents of each element in the circuit, so that not a simple voltage divider will be an accurate answer, that's why we need to use phasors to make the calculations of voltages and currents in the elements of the circuit considering the phase shift in each case. Also Transfer Function Phase tells if the circuit is unestable or not based on the gain by constructing and looking the Bode Plot out of the Transfer function specially evaluating db gain whether it is greater or lower of 0db (1) at the frequency where Phase shift is 180 degrees in a negative feedback loop configuration which will produce positive feedback and also by determined the phase margin of the circuit. Also very important to take into account the phase shift introduced by the internal capacitance of the OPAMP in use plus the added capacitance of the pcb and how to overcome this by adding zeros with high pass filters for example. Also how a capacitive load will produce inestability by adding overshoot, ringing with positive or negative exponential component, defining in which of the 4 quadrants poles and zeros lay by looking at the pole-zero plot.
I guess after 40 more hours of reading I'll be satisfied with my search
and I'll review if my concepts are clear and right
I appreciate all your responses which guided me through this road.
Regards,
Carlos
