Author Topic: Stability of opamp buffer with 200nF output capacitance?  (Read 1057 times)
Offline ocsetTopic starter
« on: November 30, 2019, 07:20:31 pm »
We are investigating getting a fixed 8V3 rail with a cheap opamp as in the attached. (it must source and sink…the opamp’s output current is as in the attached)
Can you confirm that the 4R7 resistor at the output of this MIC6211 opamp makes it stable?
Clearly the 200nF output capacitance adds a pole at 1/(2.pi.RO.CL)
Where:
Ro = opamp output resistance = 125R
CL = Capacitive load = 200nF (Ceramic X7R capacitor)
….This pole is at 63.7kHz.
I would have thought a zero is needed to cancel this pole….hence the 4R7 was added.
The 4R7 (=Rz)  adds a zero at 1/(2.pi.Rz.CL) = 169kHz
(The load resistance = 8V3/0.0085A = 976R = RL)
Clearly , there is also a load pole at 1/(2.pi.RL.CL) = 815Hz
There is also an unknown pole added inside the opamp’s  internal compensation circuitry. This is going to make it difficult to make out the Bode plot.
When I have all the poles and zeros, I can make out the bode plot and check the gain and phase margin with the 4R7 compensation resistor added.
The pole transfer function is T(s) = 1 / { 1+ j(w/w0)}
The zero transfer function is T(s) = {j(w/w0)} / { 1+ j(w/w0)}
But what are all the pole and zero frequencies?  :-//
MIC6211 datasheet
http://ww1.microchip.com/downloads/en/DeviceDoc/mic6211.pdf
(incidentally, the actual voltage across the 200nF output capacitor bank is stable in the prototype circuit we have in the lab…in fact, it is even stable if we increase the output capacitor bank to 51.7uF of ceramic X7R capacitance!!….but we want to be sure)
« Last Edit: November 30, 2019, 07:27:25 pm by treez »
Offline Kleinstein
Re: Stability of opamp buffer with 200nF output capacitance?
« Reply #1 on: November 30, 2019, 07:30:52 pm »
In the circuit as shown the extra resistor does not help with stability, it is more like an additional problem.
The right way would be to also separate the feedback with the low frequency feedback from the output, but the high frequency feedback directly from the OPs output. That is the standard way of driving capacitive loads.
The following users thanked this post: ocset
Offline jimmc
« Reply #2 on: November 30, 2019, 10:15:31 pm »
This may be of help to you, particularly the 'In-loop compensation' section. (As Kleinstein has suggested.)
https://www.analog.com/en/analog-dialogue/articles/ask-the-applications-engineer-25.html#
Jim
« Reply #3 on: November 30, 2019, 10:26:52 pm »
Thanks, sorry  ive just finished punching myself in the head a few times....i posted the wrong schem...the right one is as attached.
The schem in the top post is what we accidentally did on the first prototype.....strangley, even with the feedback  taken from the wrong place  like in the top  post, it  stays stable even if the ceramic output capacitance is increased to 51.7uF.
We appreciate that the schem in the top post is wrong (feedback taken from wrong place)...though the fact that it is stable even when capacitance is increased to 51.7uF seems to suggest that this may be workable anyway. I like the  in-loop-compensation method , but its more components, and if  just adding a compensation resistor can do it like in this post, then we'd be happy with that.....the output capacitance can be reduced to 20nF if need be.
Thanks Jimmc for the "In loop compensation" link...i noticed they are bringing the feedback back  to the non-inv input....i believe that this is a mistake?
« Last Edit: November 30, 2019, 10:49:50 pm by treez »
Offline not1xor1
« Reply #4 on: December 01, 2019, 07:04:58 am »
it looks like the swapped the the +/- inputs of the last schematic diagram
Offline gamalot
  • Correct my English
    • Youtube
« Reply #5 on: December 01, 2019, 08:10:21 am »
Maybe you would like to try something like this
I'm a poet, I didn't even know it. |  https://youtube.com/@gamalot | https://github.com/gamalot
Offline jimmc
« Reply #6 on: December 01, 2019, 03:22:45 pm »
You are both correct, that is a mistake.  Sorry I didn't spot it.
Jim
