Here is a linear power supply for audio. Someone asked me to try to repair this.
It was outputting 42V, and it was because the original toroidal transformer had failed, and as
far as I could tell that was it.
It is designed to output around 24V with 1A, as listed on the back of the supply.
There are four transistors used. Most are smd NPN/PNP, the 2GW (npn) and 558
(pnp). The 2 power transistors are D45H onsemi (pnp). There is also 1 to-92 k363 which I
think is a FET. There are two 40V 5600uf Kemet caps as input filtering, and some
tantalums, passive resistors, and an unidentified capacitor type. There's also one
diode on the second section.
2gw -
https://www.mouser.com/datasheet/2/916/BC850C-3196933.pdf558 -
https://www.diodes.com/assets/Datasheets/FMMT558.pdfd45h11g -
https://www.onsemi.com/pdf/datasheet/d44h-d.pdfI have some questions about the design for this.
- I am not familiar with what they are doing here. Is this feedback to keep
the voltage stable with the transistors? Is there a name for this topology?
Note that it is divided into two sections. The first section has a voltage divider
going into the base of the first smd transistor, then there is a pair (which
is also on the end of the second section as well). This feeds into the first power transistor
of which there are two. One at the end of each section.
What is the point of the voltage divider on the base at the start? What is the point of the npn and pnp
pair at the end of each section?
- What is the FET doing in the second half of the circuit? It seems to measure
as a voltage reference. I only tested it so far with the 42V but it was outputting around
26 volts. I assume with 24V it will output less. Everything else on the circuit was
around 42V, the FET was the only voltage that was different. I haven't tested it since
changing out the transformer.
- Is anyone interested in me reverse engineering the
second half of the circuit? I've looked at this long enough, I could probably make
my own audio power supply if I wanted to by now. Maybe someone just knows it by
looking at it. It is simple enough.
- Is there any problem with them not addressing the inrush on the toroidal transformer?
The original transformer had failed, it was outputting 42V but it was a 24V transformer.
Most switchers I see have some kind of inrush protection via the mov, thermistor, and coils.
I notice that they did nothing here. I assume as a design decision to limit noise from
extra components, but was that wise?
I replaced it with a Hammond, but the hammond website notes that inrush current is
a problem with toroidals.
- What type of capacitors are the shiny metal ones? I have seen the black tantalums before,
but I haven't seen anything that looks like these metal capacitors that are used
on the output.
- Is it even worthwhile to put a bleeder resistor across the output for the capacitors?
It seems like something else that would just add to the overall noise. Though it does look
like they used a metal film, not something like a carbon. The closest replacement for
looks I could find was a 2W 2.2K stackpole, and it looks very close, if not identical, though
the color bands on the original don't match up 1:1.
Attached is a few photos of the board, and a text file of the falstad schematic for the first section.
There is also a screenshot of what the falstad schematic looks like.
EDIT: I went ahead and reverse engineered the rest of the circuit. I don't understand the K363 / GR91 component. It doesn't appear to be wired correctly, and the simulation doesn't do much (it overloads falstad a bit), even if adding a load. Anyways, if anyone is interested, there is the 24V 1A circuit, hopefully without errors.
