Author Topic: Standard electric kettle as a DC dummy load ?  (Read 5451 times)
Offline Nusa
Re: Standard electric kettle as a DC dummy load ?
« Reply #25 on: July 15, 2018, 12:07:14 pm »
If you need to pull really high currents at low voltages, get yourself a roll of 1/4" (or 6mm for people who live in proper countries..... ;-) ) diameter thin wall copper tube, typically used for automotive brake lines.  Unroll it  into a spiral onto a wooden 'former' and by sliding the contacts up and down the spiral you can change the load.  And, using something like an aquarium or car windscreen washer pump, (or just a hose off a kitchen tap) you can pump cold water up the middle of the tube to cool it.
When i was developing a high current / low voltage DC/DC project this is what i used!
For brake line use, it has to be a certified copper-nickel alloy to be legal most places.
For cheaper copper tubing, look in the plumbing section for the stuff used for ice makers or humidifiers.
For cooling, just immersing the entire thing in fresh water is probably way easier than trying to get sufficient volume down the tube.
Offline ocset
« Reply #26 on: July 15, 2018, 12:37:08 pm »
You can make yourself an active dummy load by using  fet set up as a current regulator....eg put sense resistor in its source and regulate the voltage across the sense res using an opamp  set up as an integrator (error amplifier). And youll need a reference aswell.
And you can parallel as many as you need.
Put a heatsink on the fet(s) and thats it done.....
this saves you haveing to buy loads of different value power resistors.
Offline Seekonk
« Reply #27 on: July 15, 2018, 02:04:50 pm »
I've used pipe strapping, the 1'' steel banding with a lot of holes in it, for shunts.  Makes a pretty good resistor with a lot of surface area for getting rid of heat.
Offline edpalmer42
« Reply #28 on: July 15, 2018, 05:08:56 pm »
+1 for this.
And the holes make it very easy to connect copper cables with lugs.  Just bolt them on.
Offline lordvader88Topic starter
« Reply #29 on: July 15, 2018, 07:36:56 pm »
Well I ordered a big wire wound power resistor, 300W 1Ohm, so thats safe anyway.
I haven't got the kettle from the basement yet. I half remember some equations from chemistry for heating water, I should do a proper experiment and find out.
Offline GigaJoe
« Reply #30 on: July 15, 2018, 10:25:18 pm »
for a single 1Ohm resistor and 12V and , it would be 144W power consumed , dissipated ... for 1200W load you need 8 at least .... and each ain't cheap
10 pcs 25W 1Ohm , water cooled (or air cooled , depend on heatsink and airflow) would a fraction of single res on 300W
