Ooooh - now I understand
You would use the ATTiny instead of the scopes oscillator circuit (soldering it to the output wire).
Ok
. PWM didn't came to my mind. Yes this would be easy.
Of course I would do this only if the circuit was completely not working anymore, as it is a little modern and not using the original circuit (I would like to maintain it as original as I can).
But I have to say nice idea
I like the 2000 series too
. It has even a function my 475 doesn't have (trace separation for A and B sweep), and a nice sharp trace.
First I wanted a 2225 but I could get the 2215A for a good price and I dont't regret it.
The caps are always suspect No 1 when the scopes are not working
and sometimes some transistors, and have even seen a broken resistor (but you couldn't see that it was broken in half) shown in a scope repair report.
Have another story for you:
Two weeks ago when I repaired the light on the 475, I had another interesting problem.
On one channel all Voltages with 2 didn't work.
After taking the input attenuator box apart I found out, that one resistor had the completely wrong value (I could compare it to the other channel).
But it was not broken. And after pulling it out and measuring and setting it back into, the channel worked again and the other didn't
Problem is: many components on the 475 are socketed (which is really nice - normally - I miss this a little bit on the 2215). And so the resistor.
It simply had bad contact
. ... again something learned
Now all works fine again.
Your 2465A is really a nice scope ( and the 2235 too
- looks like the 2215 - but as far as I know the Tek scopes from 100MHz and above use many/all integrated circuits - this was the reason I bought one with lower bandwidth).
I would not really need my scopes for work, but I ever wanted one when I was a kid
. And now I have three of them.
I wouldn't want to miss them. I hope I have more useful things to do for them in the future.
And repairing and maintainig it's function is part of the fun for me
Nice greetings, Tom
