Author Topic: Starting with modular synths, DAC Question  (Read 1312 times)
Offline calliTopic starter
  • 3D Blender and Maker
    • Blender Buch
« on: December 01, 2019, 05:12:08 pm »
I stumbled into that rabbit hole... There is so much fun to build yourself in that modular synth region  ::) >:D
So I thought first build something digital/analog to get my hands dirty and stay a bit in my comfort zone, so I am doing a LFO (low frequency oscillator) generating waveforms with an arduino. That part works, I use a MCP4921 12-bit DAC.
So have a look at the attachments, on low frequencies (note the Time/Div) I get a banana curve?! I swear I only add constant values to my variable an would expect a linear sawtooth curve...
Is the MCP4921 not linear? Or do I have an error here?
My loop looks like so (codensed to the bare minimum, real one has some more stuff but error is the same):
void loop()
x = x + 1;
if (x>=4096) x=0;
myDac.analogWrite(x);
delayMicroseconds(20);
Later I may come here to ask some OpAmp Questions, but so far I can generate the CVs with them ok and also drive stuff with it, also build my vactrol etc :)
Cheers,
Carsten
Carsten Wartmann: Make Magazin DE - Autor - Dozent - 3D - Grafik - Maker
http://blenderbuch.de/
Offline Kjelt
Re: Starting with modular synths, DAC Question
« Reply #1 on: December 01, 2019, 05:15:15 pm »
Be carefull or your livingroom will end up like this
    • Blender Buch
« Reply #2 on: December 01, 2019, 05:24:50 pm »
Yea... I guess not as I am a loser at musicality  :scared: And I do not play the lottery.
Carsten
Offline Kjelt
« Reply #3 on: December 01, 2019, 05:25:38 pm »
But to answer your question i dont know this dac but if i look fast in the datasheet you can not just put 0...4095 through spi since it expects 16 bits where some bits have a change in behaviour like the 2x gain which will interpret 0..2047 differently from 2048..4095 reread the datasheet or place the full code here.
Offline MarkF
« Reply #4 on: December 01, 2019, 07:09:25 pm »
I have used the MCP4822 DACs with a SPI interface and the MCP4921 interface is similar.
Like @Kjelt says, you must pack the 12-bit DAC value into two bytes.  See the datasheet.
The code snippet you posted is doing an analog output via an Andrino PWM pin.
You MUST instead setup and use the SPI library to send data to the MCP4921.
The data format is:
882858-0
    • Blender Buch
« Reply #5 on: December 01, 2019, 07:20:46 pm »
I am using https://github.com/michd/Arduino-MCP492X as library. Seems to handle that.
However, I also tried it the hard way and same result, "banana".
#include <MCP492X.h> // Include the library
#define PIN_SPI_CHIP_SELECT_DAC 9 // Or any pin you'd like to use
MCP492X myDac(PIN_SPI_CHIP_SELECT_DAC);
#define DATAOUT     11  //MOSI
#define SPICLOCK    13  //sck
#define SLAVE1       9  //ss
#define LED       8
#define FREQ      A0
#define ATTE      A1
#define FAST      7
unsigned int freq = 0;
unsigned int atte = 0;
unsigned int x = 0;
unsigned int fast = 4;
void setup() {
  myDac.begin();
  pinMode(SLAVE1, OUTPUT);
  pinMode(FAST, INPUT_PULLUP);
  pinMode(LED, OUTPUT);
  Serial.begin(57600);
int dir = 1;
// siplified version
void sloop()
  x = x + 1;
  if (x >= 4096) x = 0;
// "Production" :)
void loop() {
  if (digitalRead(FAST))
    fast = 3;
    freq = (analogRead(FREQ)) + 1;
  else
    fast = 0;
  if (x % 8 == 0)
    freq = (analogRead(FREQ)) + 1; // Maybe IRQ?
    atte = (analogRead(ATTE)) + 1; // Maybe IRQ?
  x = x - (freq << fast);
  Serial.print(x >> 4);
  Serial.print("    ");
  Serial.println(atte);
 // using overflow of unsigned int as wraparound, could be malious but see above simple version
  myDac.analogWrite((x >> 4)); //Simple again
  //myDac.analogWrite(map(x>>4,0,4096,0,atte<<2)); // attenuate using Map and a second poti
  if (fast == 0)
    delayMicroseconds(1024 - freq);
Offline MarkF
« Reply #6 on: December 01, 2019, 07:57:47 pm »
Some of this may be wrong or unnecessary.  I rarely do Arduino code.
// set pin 10 as CS for DAC:
const int CSpin = 10;
// DAC value
int value = 0;
void setup()
  // set Chip Select as output:
  pinMode(CSpin, OUTPUT);
  // initialize SPI:
  SPI.begin();
  SPI.setDataMode(SPI_MODE0);
  SPI.setBitOrder(LSBFIRST);
void loop()
  // Set CS low
  digitalWrite(CSpin, LOW);
  // Transfer value
  //   (you will need to 'OR' in additional bits for the 2nd output)
  SPI.transfer16(value);
  // Set CS high
  digitalWrite(CSpin, HIGH);
  // Increment DAC value
  if ( (++value) > 4095 ) value = 0;
  // Delay
  delayMicroseconds(10);
Offline jhpadjustable
  • Salt 'n' pepper beard
« Reply #7 on: December 01, 2019, 08:00:12 pm »
Cute vactrol :)  But, you should really post a schematic. In particular, where is your Vref coming from?
"There are more things in heaven and earth, Arduino, than are dreamt of in your philosophy."
    • Blender Buch
« Reply #8 on: December 01, 2019, 08:05:20 pm »
Yea, thats the hard way. Tried that also.
I feel the vref thingy could be a thing.
C!
Offline dmills
« Reply #9 on: December 01, 2019, 08:06:07 pm »
I think its simpler then that, try switching the scope to DC coupling!
Regards, Dan.
The following users thanked this post: calli
    • Blender Buch
« Reply #10 on: December 01, 2019, 08:21:30 pm »
Regards, Dan.
 |O |O |O |O |O
Oh man....
Thanks!
