Author Topic: stepper motor  (Read 1967 times)
Offline abdullahsebaTopic starter
stepper motor
« on: March 25, 2014, 03:23:15 pm »
can you connect a 3v stepper motor to 5 volts
This is my right hand this is my wrong hand
Offline michaelym
Re: stepper motor
« Reply #1 on: March 25, 2014, 08:40:13 pm »
Generally when a motor is "rated" for a certain voltage it just means that the specs for torque, etc. in the datasheet were measured at that voltage.
I believe it shouldn't be a problem.
Offline hlavac
  • Country: cz
Re: stepper motor
« Reply #2 on: March 25, 2014, 08:49:51 pm »
Its not like the voltage rating of the stepper motor means the isolation on the coils breaks down at that voltage or something, it is related to the power rating of the motor (you can put as much DC current thru the motor that develops 3V across the internal resistance and it should barely not burn).
In fact higher voltages are commonly used to get the current in the coils going faster - they are inductors right? - for high speed operation, as long as you don't exceed the power rating and back off on the voltage to 3V / limit the current when the max rated current is reached it will be perfectly fine.
Normally you think in terms of current not voltage when driving stepper motors...
Good enough is the enemy of the best.
Offline hlavac
  • Country: cz
Re: stepper motor
« Reply #3 on: March 25, 2014, 08:55:53 pm »
As for the 5V, yes but not permanently :)
You will need to do for example some PWM to keep in the allowed power rating. Duty cycle of 3/5 or 60% will do it for you...
