After two months of use, I noticed the LEDs weren't as bright, even though there's been plenty of sunlight.
I opened up the casing and measured the 18650 battery inside at 4.9 volt. This seemed unsafe, so I sent it to the recycling bin and meanwhile I've been trying to understand the circuit, so I can keep using it in a safely manner.
Please note the photos in attachment:
- solar panel outputs close to 6V under direct sunlight;
- if the solar panel isnt plugged in, the LEDs light up whenever there is movement; when it's plugged it, the LEDs only light up at night.
My conclusion is that PIN6 is pulled High when the solar panel is connected, disabling the PIR but charging the battery through the transistor.
If the panel is at 6V, is the 18650 exposed to those 6V and will take as much current as the solar panel can provide, considering the base of the transistor is biased by the 100 ohm and 10kohm resistors?
Also, the LEDs are exposed to over 4.2V, correct? They pulled 600mA at 3.3V under test...
Regarding making charging safer and LEDs last longer, can I connect the emitter to the input of a TP4056 board to charge the battery (output to B+ L+)? Can I solder resistor to the anode of the LEDs to limit the current, when B+ is at 4.2V?
