If you didn't get answer then it's because nobody tried, simple as that.
Who knows the heater used in these guns. 240V? 24V? Temperature sensor output?
Would need at least a custom firmware running on the said boards and some hardware mods.
You still need the vacuum pump, the enclosure...in the end it's just better to get the real thing.
