Hi All,
For my first project I was looking at building a simple linear power supply based on the LM317 chip. I built up the circuit yesterday (breadboard) and the voltage, relay and current controls are all working as expected.
As discussed in a previous thread, to determine if the supply is in current limiting mode, I am using a differential amplifier to the look at the voltage drop across the first 317 (in the attached circuit) and then compare the output to a reference voltage. If it’s greater than 2V in this case, the comparator lights a LED.
The circuit works well but I have a small issue with the current limiting LED turning on briefly whenever the power switch is flipped (on or off). I have rebuilt the circuit without the relays and it still occurs. I also have added a separate voltage regulator for the opamp and comparator but still no luck. I also added some hysteresis to the comparator but I still get the issue.
Any ideas on what this could be? Any guidance on what I should look for would be appreciated. I am currently using a cheap plug pack to power the system and I wonder if that could be the issue?
Thanks
