Hi guys,
I am working with the LoRaWAN_End_Node example provided in STM32WL SDK.
https://github.com/STMicroelectronics/STM32CubeWL/tree/main/Projects/NUCLEO-WL55JC/Applications/LoRaWAN/LoRaWAN_End_Node (https://github.com/STMicroelectronics/STM32CubeWL/tree/main/Projects/NUCLEO-WL55JC/Applications/LoRaWAN/LoRaWAN_End_Node)
I want to set up the calendar and get the time and date. The example itself initializes the RTC in rtc.c. Then I configure the time and date and I call getTime and getDate from the main.c
My problem is that the time does not update and the seconds are always 0 as shown in the image below.
However, when I create a fresh new project the calendar works fine. But when I work with the End_Node example it doesn't. I have also read the AN5406 but I didn't find any related information.
https://www.st.com/resource/en/application_note/an5406-how-to-build-a-lora-application-with-stm32cubewl-stmicroelectronics.pdf (https://www.st.com/resource/en/application_note/an5406-how-to-build-a-lora-application-with-stm32cubewl-stmicroelectronics.pdf)
Any help?
rtc.c file
/* USER CODE BEGIN 1 */
void setTime(void) {
sTime.Hours = 16;
sTime.Minutes = 0;
sTime.Seconds = 0;
sTime.DayLightSaving = RTC_DAYLIGHTSAVING_NONE;
sTime.StoreOperation = RTC_STOREOPERATION_RESET;
if (HAL_RTC_SetTime(&hrtc, &sTime, RTC_FORMAT_BIN) != HAL_OK) {
Error_Handler();
void setDate(void) {
sDate.WeekDay = RTC_WEEKDAY_SATURDAY;
sDate.Month = RTC_MONTH_AUGUST;
sDate.Date = 13;
sDate.Year = 0;
if (HAL_RTC_SetDate(&hrtc, &sDate, RTC_FORMAT_BIN) != HAL_OK) {
Error_Handler();
void getTime(void) {
HAL_RTC_GetTime(&hrtc, &sTime, RTC_FORMAT_BIN);
void getDate(void) {
HAL_RTC_GetDate(&hrtc, &sDate, RTC_FORMAT_BIN);
/* USER CODE END 1 */
main.c
while (1) {
getTime();
getDate();
HAL_Delay(1000);
(https://i.ibb.co/x1WwNGh/Screenshot-4.png) (https://imgbb.com/)
Have you heard of a joke "write only memory"? Such device would conceptually be pointless. So that's why it is a joke.
When I was talking about compiler optimizations, I meant that compiler tries to avoid any pointless operations. In optimizing compiler's opinion, your code:
while (1) {
getTime();
getDate();
HAL_Delay(1000);
might be equivalent to:
while (1) {
HAL_Delay(1000);
because it is pointless to get time, write to memory structure when it is never used and in fact after 1 second it is supposed to be overwritten and again never used. Compiler does not know that you attach a debugger and have intention to actually read that memory location. Note: this example is not entirely true, because low level RTC access should not be optimized out (register access) even if it is pointless, but write to structure may very well be.
Your problem might be different, but I'm suggesting you first eliminate the possibility of compiler "tricks".
