For each RTD use the switches from a single package, so that the on resistance is equal for each switch. The resistance differs from package to package slightly, and you really want then to be both close and to track with temperature of the switch. You want a mux with lower resistance, or to use a Pt1000 sensor, which will have reduced error from the switch resistance.
