Author Topic: strange output on CRO while measuring output of 45Mhz  (Read 1239 times)
Offline Vindhyachal.taknikiTopic starter
« on: February 08, 2019, 03:17:56 pm »
I am measuring output of 45Mhz of programmable oscillator of: http://www.cardinalxtal.com/products/programmable-oscillator-3
1. When I measuring it on gwinstel gds-11028 DSO,.
2. Gnd loop is mimized, like this: https://goo.gl/images/QqHD2d
3. Probes are conencted directly on oscillator output pins
4. Vdd = 3.3V
5. When on 1x probe:  Signal is sine wave riding on 1.6Vdc. Peaks of sine wave dont touch the 3.3V & 0V limtis.
6. When on 10x probe, signal is sine wave which seems to ride on dc also, but this time negative peak of sine goes below zero volt
7. Why is that so?
8. Also  what is output of this oscillator, we have TTL version, is it sine wave?
I thought it would be square wave.
Offline Zero999
  • 0999
Re: strange output on CRO while measuring output of 45Mhz
« Reply #1 on: February 08, 2019, 04:23:18 pm »
I couldn't find the gwinstel gds-11028, using Google. Presumably you mean the GDS-1102B?
https://www.testequity.com/documents/pdf/GDS-1000B-brochure.pdf
It's a 100MHz oscilloscope and you're measuring a 45MHz squarewave. An ideal square wave only contains odd harmonics, so you have 45MHz, plus the 3rd, 5th, 7th etc. harmonics 135MHz, 225MHz, 315MHz, but your oscilloscope will have a filter blocking everything below 100MHz, so you just see the fundamental of 45MHz.
In other words, this is exactly what you should expect. To see anything resembling a square wave you need a much wider bandwidth oscilloscope.
Offline alsetalokin4017
« Reply #2 on: February 08, 2019, 04:25:09 pm »
The short answer is that you can't really measure a 45 MHz square wave with a 100 MHz oscilloscope.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #3 on: February 08, 2019, 05:05:08 pm »
7. Why is that so?
with unterminated 1X coax cable, so you probably looking at one point in standing wave.
with 10X probe, no reflection in probe cable, there maybe a little bit of loading in the circuit though. it goes -ve i guess due to overshoot in square wave signal or a little reflection due to mismatched cable. without properly measuring it with the right tool, we are actually measuring a funny business... attached is an example of 5V 125MHz oscillator clock in not so good terminated transmission line. if we let loose the termination it will become haywire. ymmv..
Online David Hess
  • DavidH
« Reply #4 on: February 09, 2019, 03:54:22 am »
Check to make sure the x10 probe is compensated correctly or it can increase the amplitude of high frequency signals.
Offline Zero999
  • 0999
« Reply #5 on: February 09, 2019, 09:37:18 am »
Another option is a low-Z probe, which can be made with a piece of 50Ω co-axial cable and some resistors. It will have an impedance of 500Ω over a wide range of frequencies. At low frequencies, the ×10 probe will have a higher impedance, but at high frequencies, above 20MHz or so, its impedance drops below that of the low-Z probe, which remains constant.
The above is just for future reference. Your oscillator should be capable of driving a low-Z or ×10 probe, with no problems. As previously noted, it's the oscilloscope's limited bandwidth which is causing the square wave to appear sinusoidal, rather than the probe.
Offline taydin
  • Country: tr
« Reply #6 on: February 09, 2019, 10:14:01 am »
I haven't seen such a filter in a number of oscilloscopes I have used. But the analog front end will start attenuating signals beyond its stated bandwidth, which effectively behaves like a filter, but that would only be a very mild filter. When I apply a 0 dBm, 4 GHz sine wave to my 1 GHz scope, I am still comfortably seeing the signal with about 23 dB attenuation.
Spectrum analyzers always have a very sharp cutoff filter at their rated bandwidth, because without that filter, frequencies above the bandwidth will raise the noise floor within the rated operating bandwidth.
« Last Edit: February 09, 2019, 10:17:28 am by taydin »
Real programmers use machine code!
My hobby projects http://mekatronik.org/forum
