Author Topic: Strange Power Supply Behavior  (Read 780 times)
Offline KingSolomonTopic starter
« on: January 20, 2020, 10:31:21 pm »
Hello-
 I recently got a new Siglent bench power supply. However, it has started to have a strange behavior of defaulting to constant current mode when I turn it on. I don't think that this is normal. Is this a common issue with an easy fix? I should also note that I have not put it under any stressful conditions since I bought it.
Thank you!
« Last Edit: January 20, 2020, 10:35:29 pm by KingSolomon »
Offline Prehistoricman
Re: Strange Power Supply Behavior
« Reply #1 on: January 20, 2020, 11:14:17 pm »
What model is it?
« Reply #2 on: January 21, 2020, 02:17:58 am »
Offline vu2nan
  • Country: in
    • Amateur Radio - VU2NAN - Nandu
« Reply #3 on: January 21, 2020, 04:24:17 am »
Offline Jwillis
« Reply #4 on: January 21, 2020, 04:51:14 am »
Not sure what version you have but  you could check if it has the latest firmware. https://siglentna.com/service-and-support/firmware-software/dc-power-supplies/#spd3303c-series
« Reply #5 on: January 21, 2020, 05:06:40 am »
I don't think that is the issue. I live in 120V North America, and have set the supply accordingly. Thank you
