Author Topic: MCU based inverter design  (Read 2234 times)
Offline baoshiTopic starter
  • Country: sg
    • Digital Me
« on: December 21, 2013, 03:53:21 pm »
I'm designing a VFD driving circuit. One of the challenge is the driving chip needs -22V negative bias.
I found Dave has an inverter FF tutorial based on a MCU generate waveform. But it can only provide -VCC instead of "boost" the voltage lower.
So I came out the attached design, basically combining a boost converter with Dave's inverter.
Can someone scrutinize my design before I put it onto a board?
Thanks
Baoshi
Offline Marco
Re: MCU based inverter design
« Reply #1 on: December 21, 2013, 04:14:02 pm »
Heh, nice effort to try to modify such a simple circuit until it does what you want to do ... but you get so far away from Dave's circuit that it stops making sense to even use it as part of your design.
You want a (inverting) buck boost converter with a P mosfet.
« Last Edit: December 21, 2013, 04:15:56 pm by Marco »
  • Country: sg
    • Digital Me
« Reply #2 on: December 22, 2013, 03:39:50 am »
Thanks Marco,
I changed the design. Is this any good?
