Concur, 12Mb/s USB is not usually all that delicate.
Ground pours are better then thin traces, do them on BOTH sides of the board and via stitch extensively, still much worse then a nice solid plane, but better then what you have, and as said, think about current loops, they are key to anything high speed.
Vias are cheap, keep adding stitching until your board vendor starts putting the cost up because of too many vias,then back off just a little....
I would be very surprised if CircuitMaker cannot do at least 4 layers, that would make it basically useless for anything faster then audio.
Regards, Dan.
