I'm in the process of replacing some 3-way switches with some combo 3-way & outlet, and just came across a really weird wiring setup that has left me stumped. I should have taken pictures of the wiring before I took everything apart, but I wasn't expecting the wiring that I found after I removed the switch in the 2nd box. Hopefully my description is good enough.
There is a light switch at the bottom of the stairs, and 2 light switches at the top of the stairs. The light switch at the bottom of the stairs is a 3-way, and one of the switches at the top of the stairs is a 3-way, which control the lights in the basement. The 2nd light switch is a regular light switch that controls a single light at the top of the stairs.
The main 12/2 line from the breaker goes into the box at the bottom of the stairs. In that same outlet box there is a 12/3 line, and another 12/2 line. Seems normal enough, I figured the 2nd 12/2 was to get power to the box at the top of the stairs for the single light switch since its on the same breaker.
The 2nd outlet box is a double size, as it has the 2nd 3-way switch and a separate regular switch (no combo switches). In this box, you have the 12/3 line coming into it, a 12/2 line going to the lone light at the top of the stairs, and then another 12/2 line coming in. I assumed that the 2nd 12/2 was the 12/2 from the first box bringing power to this box for the regular switch, and the 12/3 was wired with the lights between the two 3-way switches, so I'd have to break out the multi-meter and verify which wire should be which in the 3-way circuit as no wires were taped to designate Hot/Neutral/Red.
Except the 12/3 wasn't feeding any of the lights in the circuit and was just a straight run from the first box, to the 2nd.
And that 2nd 12/2 in each box? Turns out that 2nd 12/2 line in the first box is the same 12/2 line in the 2nd box as I assumed, but wired to the lights in the basement.
And every light in the basement is wired properly like a normal circuit would be, Hot (Black) to the center pin in the light socket, Neutral (White) to the threads in the socket. This corresponds to the 12/2 in both boxes.
Again, I know I should have taken pictures before just tearing everything apart as I wasn't expecting anything out of the norm (still kicking myself for that), but somehow with this wiring, they manged to not only control the lights in the basement with the 3-way switches, but also provide power to the lone light at the top of the stairs separate from the 3-way circuit, with the 12/3 wire run NOT going to the lights (as one would expect with lights BETWEEN two 3-ways). From what I recall, none of the wires were mixed (no Neutrals, Hots or Reds wire nutted together), none of the wires are wrapped with colored tape (which was done on other circuits in the house so the electrician would have done the same here), and every wire was connected to something, no wire was left hanging all alone.
I thought this would be a simple job, but I can't figure this circuit out, and I'm at the point I'm just gonna wire everything straight to power and leave the 3-way switches out of the circuit and use smart lights instead, but I'd like to have the switches in play, even if I never actually use them cause of the smart lights (plus why have switches if they don't do anything
). Anyone wanna take a crack at this puzzle?
