Author Topic: Identification of 2 chips  (Read 2855 times)
Offline StonentTopic starter
« on: June 19, 2013, 06:46:46 pm »
I can't find anything on the part number on Toshiba's site, and the other one I can't even tell who makes it.
Both came out of a USB Glucose tester.  A previous revision of the tester used an STM32F103 Cortex M3 chip so I suspect one of these might be an ARM chip.
Pictures of these chips on the board are here: https://www.eevblog.com/forum/chat/this-might-make-an-interesting-teardown-(free-usb-glucose-meter)/15/
Also if it helps both chips are about the size of 1/2 of your small finger's nail. (6 or 7 mm?)
« Last Edit: June 20, 2013, 03:20:13 am by Stonent »
Offline Caleb_P
Re: Identification of 2 chips
« Reply #1 on: June 19, 2013, 08:07:35 pm »
Most likely custom badged chips. If you buy enough or pay extra, the manufacturer will gladly put whatever labeling you want on the chip.
Offline Paul Price
« Reply #2 on: June 20, 2013, 01:36:57 am »
The one on the left is definitely not an ARM chip.
« Reply #3 on: June 20, 2013, 03:23:39 am »
Why? Do all ARM chips have to say ARM on them or something like that?
Offline amyk
« Reply #4 on: June 20, 2013, 12:24:17 pm »
I'm inclined to say it might be ARM-based, given that Toshiba has a few and the older design was ARM-based too.
The BGA on the right is also present on the older version, some sort of analog front-end processing I'd guess.
« Reply #5 on: June 21, 2013, 01:50:26 am »
Possible identification of the second chip:
http://datasheet.octopart.com/UPD70F3796GC-UEU-AX-Renesas-datasheet-10979623.pdf
Renesas UPD70F3796.. I don't know for sure if I'm right, but the part number is a partial match and they do have lqfp and bga versions.
More possible proof, on their applications page they show a some medical devices and one of the pictured devices is an unmarked Bayer glucose meter (same "contour" brand, but different design)
http://documentation.renesas.com/doc/DocumentServer/R01CL0029ED0200.pdf
Integrated 256 to 1024k flash, 100 to 128 pins, 40 to 80k ram, 2.0 to 3.6v.
http://am.renesas.com/press/news/2011/news20110808.jsp
Renesas Electronics America Announces V850 Microcontroller Demonstration Platform for Continua®-Certified Blood Glucose Meter Agent
« Last Edit: June 21, 2013, 02:10:48 am by Stonent »
Offline amyk
« Reply #6 on: June 21, 2013, 08:31:09 am »
I think you hit the nail on the head. Good work!
That's a pretty full-featured MCU with lots of peripherals. Unfortunately it's also a relatively obscure architecture and also has a "disable chip erase" security setting, so it might not be able to be cleared and repurposed easily.
The older revision of the device has a Matsushita BGA in its place. Something else equally obscure...?
« Reply #7 on: June 21, 2013, 09:05:51 am »
Yeah, I had my heart set on an ARM chip, even a low end one like the STM32 or Atmel SAM.
But I am considering getting a cheap digital logic analyzer so maybe would be something interesting to probe around on. There's certainly enough test points.
