Is there a way to modify the isolation transformer so instead of blowing fuses if a DUT tried to draw too much current, it would temporarily shut down until the load was removed or the short / whatever was fixed?
I thought maybe a PolyFuse, but I think they would be a really bad idea here because I don't think they make one with the proper paremeters, such as the Vmax or Imax being acceptable to just replace the fast acting fuses with a PTC. I also worry that maybe they wouldn't open fast enough. I was thinking maybe with some additional parts, I could use a PTC or something. I feel I might blow a fuse more times than I'd like to replace them, using this to help repair electronics.
Why would a ground plane or a grounded chassis on the DUT cause problems with an isolation transformer? To the isolation transformer, doesn't it just appear that the secondary side of the transformer is the primary power source? The begining and end of the circuit?
**EDIT: I think I made a mistake, thinking I was done with the modifications of this isolation transformer. I unhooked the grounds from the outlet side and from the chassis side, however, I really think I should have the grounds connected to each other, but still floating. This way, let's say two people are working on two seperate devices, and both devices have a short. One to line, one to ground. If they don't realize it and touch each other, while touching their DUT, they could be shocked, perhaps fatally. So I think I should daisy chain the output grounds together, and leave them floating (just connected to each other).
