Asking is precisely what this forum is for. The purpose of the relay, is to relieve the NTC (here, also called an inrush limiter) of the temporary soft-start task, that's all. I chose two (10 ohm/ 5 amp) in parallel because they're a common find when harvesting parts and 5 ohms should be sufficient for a breaker not to trip. PC power supplies use them to soft charge the input bulk capacitors and often they look like large dark-green or black ceramic capacitors, with a sandy hi-temp exterior. See pg. 29 here http://www.farnell.com/datasheets/33552.pdf
I have seen them before and I have done some research in the past on them. Are they always used as an inrush limiter? My understanding is the resistance changes with temperature. The higher the temp, the less resistance. soft-start task....I know there's a huge in-rush current with the startup of an AC motor, but there's also one with transformers? I can purchase this one:
https://www.mouser.com/ProductDetail/Ametherm/SG336?qs=sGAEpiMZZMtPe6tiLMgnfDIkRBydcYq9ZpRZtoOVAxM3vGe5MWY2Wg%3D%3Dif I just wanted one, instead of using two in parallel, right?
A 555-timer (2 second monostable circuit) drives a transistor and relay, which powers the relay shunting/closing it across the NTC inrush limiter(s). The small 9-12v transformer powers the 555 circuit and relay, and its primary could be could be connected either on the input or output side of the isolation transformer. I would use the output side, since any shorted DUT on your bench will open the relay making the line-side surge a little softer for other devices using that same distribution circuit. I'll have to assume for the moment, your 1kVA unit will have a fuse or breaker integrated (??)
I have some 555 timers, which I could use. I received the isolation transfomer today, damaged, of course. That's my luck. Mail lady entered the damage in the system and said if the actual unit was damaged, to contact the seller, who would start a claims. I did that. We figure one of the postal people dropped the box. The box was damaged, the isolation transformer is damaged. It's the mounting brackets.
So I contacted the company who made the transformer to see if they could get me a price on replacement mounts, and they said they'd contact me by the end of the day with an answer. Right now, I don't really need the mounts, but eventually, I'd love to mount this to my work bench. That's where I'd be using it once my daughter gets a bit older. I cannot use the current mounts. If I unbent them, the metal wouldn't be structurally sound anymore, and the thing could end up falling and hurting someone.
