Author Topic: Suitable and cheap heatsink  (Read 1820 times)
Offline VEGETATopic starter
  • Country: jo
  • I am the cult of personality
    • Thundertronics
« on: November 08, 2018, 01:01:09 pm »
Dear friends,
I have a project to make electronic load which is 30v 2A only, but I plan to make it 30v 5A with a max of 150W in the future.
Will this heatsink be enough: https://www.aliexpress.com/item/1-PCS-100x41x8mm-Aluminum-Radiator-Heat-Sink-Heatsink-for-Computer-LED-Amplifier-IC-Transistor-Computer/32914236957.html
I only want cheap stuff from aliexpress especially for shipping, if I am fortunate enough to be able to sell it in future.
I am open to use a cheap 12v fan or so if it helps.
Offline GeoffreyF
Re: Suitable and cheap heatsink
« Reply #1 on: November 08, 2018, 01:04:53 pm »
Any piece of heat conductive metal such as aluminum or copper is fine.  If it is made with fins, that's better.  If it has no fins, make it a little bigger.
US Amateur Extra W1GCF.
Offline CJay
« Reply #2 on: November 08, 2018, 01:11:08 pm »
No idea, the specs on there relate to a fan, not a heatsink and your specs are pretty vague too, you need to know specs for the devices you're going to mount, decide on an acceptable max temperature over ambient for the heatsink and a few other things.
You could find a similar size heatsink from a supplier that gives proper specs and assume they're approximately the same, then do the heatsink calculations (which are pretty simple)
Gut feeling is that yes, it'd probably do but it'd be useful to you in the future to be able to specify and design it properly.
Offline hayatepilot
« Reply #3 on: November 08, 2018, 02:19:52 pm »
The linked heatsink is way too small for 60W let alone 150W!!
It is only 8mm high.
Just look at how big a CPU heatsink is, which dissipates about the same power.
This heatsink is the size you would need: https://www.dhgate.com/store/product/50-150w-high-power-led-heat-sink-led-cooling/176904642.html
And it needs a fan too for full dissipation capacity.
Greetings
Offline IanMacdonald
    • IWR Consultancy
« Reply #4 on: November 08, 2018, 04:30:40 pm »
Bear in mind it's the sum of the thermal resistances of the device itself, its case, any mounting washer and the h/sink that have to be added to determine the power rating. Just fitting a larger h/sink to an underrated device soon gets into a law of diminishing returns.
For this kind of duty, avoid TO220 devices as you just can't get an adequate thermal bonding to the h/s on so small a case. TO247 or TO3 will be a better bet, though even so one would be stretching things, think in terms of at least two in parallel.
Going fan assisted will definitely lead to a smaller and probably cheaper unit than a monster convection h/s. Thermostatic control them becomes preferable to avoid too much noise on light loads. Although that does call for a separate fan supply, of course, which convection cooling avoids.
« Last Edit: November 08, 2018, 05:03:26 pm by IanMacdonald »
  • Country: jo
    • Thundertronics
« Reply #5 on: November 08, 2018, 07:45:50 pm »
I ordered one and another different one to test them. I will mount 4 N-Mosfets IRILZ44N (isolated package) on it, I already ordered the threading tool too.
right now it is only 60W for this project but the future upgrade must be 150W.
I will put everything in aluminum enclosure of 100x100x50 mm dimension.
Offline hayatepilot
« Reply #6 on: November 09, 2018, 10:06:45 am »
Please let us know your results/temperatures.  :-DMM
Imho that heatsink is too small for a sustained full load. You might get by for a minute or two at full load.
Greetings
  • Country: jo
    • Thundertronics
« Reply #7 on: November 09, 2018, 01:33:31 pm »
Greetings
I will do Inshalla.
I am not really confident that this will be enough, but for now, it might be suitable for the 30v 2A version.
Offline mvs
« Reply #8 on: November 09, 2018, 02:41:04 pm »
I use 20 cm²/W as a rule of thumb for passive cooling. With ~350cm² heatsink from your first post, this mean 17.5W cooling capacity.
With a fan this heatsink will be probably sufficient for 60W, but I would recomend you to use some CPU Cooler instead.
