Hi everyone,
I have an audio amplifier IC that has a mute feature I want to control to reduce pops on power on / off.
The mute is a CMOS compatible pin where HIGH disables the mute, effectively enabling the amp.
I have found that the pin is actually fed internally in the amp IC via a high resistance so that if left open it will enable itself. When I connect a capacitor between the mute pin and ground it will slowly charge and enable the amp gently at power on. That's nice.
What I want to do is have a JFET that bleeds the pin to ground quickly when the power is switched off and the rail starts to fall.
I've only got positive voltage (+15V) available so I guess it needs to be a P-channel JFET.
I 'm thinking if I drive the gate via a resistive diver that only just exceeds pinch-off voltage when the rail is a full potential, it should close the circuit between mute and ground as soon as the main rail starts to drop. Does that sound sensible?
What kind of JFET part number would be suitable? A small SMD part is great.
