Author Topic: Suitable replacement for AT27C1024 IC  (Read 1332 times)
Offline giosifTopic starter
« on: October 08, 2022, 06:01:12 pm »
I am looking for a suitable replacement for an Atmel AT27C1024 OTP EPROM IC in TSOP/VSOP-40 package, as it seems it's not that easy to find (let me know if you happen to have a spare one or know where to get one at a reasonable price).
The replacement IC can be either EPROM (OTP or otherwise) or EEPROM and could have larger capacity (the AT27C1024 has 1Mbit - 64K x 16 - capacity), as long as the pinout is the same.
Anyone has any suggestions, please?
Thanks!
Offline wraper
  • Country: lv
Re: Suitable replacement for AT27C1024 IC
« Reply #1 on: October 08, 2022, 06:25:11 pm »
You can still get one. https://www.utsource.net/itm/p/4142325.html Even though it says used, IME it likely will be NOS. There are a lot of suitable replacements including NOR FLASH like AT49F1024A, the issue is almost all of them are equally hard to buy in TSOP-40 package. And you need to spend a lot of time to search for all possible replacements and if you actually can buy them.
« Last Edit: October 08, 2022, 06:28:01 pm by wraper »
Offline Benta
« Reply #2 on: October 08, 2022, 07:31:50 pm »
I don't think many EPROMs/OTPROMs are used any more. I'd look to Flash replacements instead, better availability.
Offline CaptDon
  • Country: is
« Reply #3 on: October 08, 2022, 07:41:54 pm »
Can't really say I have seen many offerings of quartz window eproms in small outline packages? Everyone simply went to single voltage flash memory which are available in SOP.
Offline Benta
« Reply #4 on: October 08, 2022, 07:50:37 pm »
The OP wrote "OTP EPROM". No quartz window there.
Offline CaptDon
  • Country: is
« Reply #5 on: October 09, 2022, 03:45:13 am »
"The replacement IC can be either EPROM (OTP or otherwise)"
« Reply #6 on: October 11, 2022, 05:53:28 pm »
Thank you all for the answers!
I have found (and ordered) an AT49F1024 from a seller in China.
Might turn out to be a dud, but the price was low enough to take the risk.
Offline james_s
« Reply #7 on: October 11, 2022, 06:24:59 pm »
There's a very good chance it's counterfeit, but I guess you could get lucky.
« Reply #8 on: October 12, 2022, 01:38:41 pm »
You are probably right but, for the money, I thought I might just as well give it a try.
