I am trying to find a replacement for a Sanyo ML2430 rechargeable battery, but with not much luck so far (not at a decent price, anyway).
Thing is, the said battery is a Lithium Manganese Dioxide type, while most of the similar batteries I've found are the Lithium Vanadium Pentoxide type.
Is it safe to use this latter type instead of the former, considering the circuit it is part of will try to charge the battery?
If it's not a good idea to do that, anyone has any suggestions where I could source an ML2430 battery from and at a reasonable price?
Thanks!
