Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Hot air solder station query
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Hot air solder station query (Read 3267 times)
gregoryfenton
Newbie
Country:
on:
August 25, 2012, 08:38:45 pm »
Please don't flame me
I have just purchased (and am awaiting delivery of) a solder station reviewed by our very own Dave (ATTEN 858D+, eevblog #167).
My question is this: Can I use a hot air solder station to do normal through hole soldering?
I have spent hours today trawling the internet watching videos and researching but I can't find anywhere that gives me the answer.
I hope that this site and its users can answer the question for me.
Logged
8086
Super Contributor
Country:
Re: Hot air solder station query
Reply #1 on:
August 25, 2012, 08:40:10 pm »
It would probably work to some degree, but basically no. Use an iron for that.
Logged
gregoryfenton
Newbie
Country:
Reply #2 on:
August 25, 2012, 08:42:02 pm »
Thanks for the quick reply 8086.
Logged
Fraser
Super Contributor
Country:
Reply #3 on:
August 25, 2012, 09:43:58 pm »
What you can do is pre-heat a pcb using the largest hot air nozzle to reduce thermal shock to components and help with soldering to large groundplane copper masses that would otherwise act as a heatshunt.
Hot air guns can perform desoldering of through hole components but it is less efficient than direct contact desoldering and risks scorching the PCB if not done well. Soldering with such a unit would prove challenging if you used 'wire' solder as opposed to solder paste. The wire solder would melt every time you brought it into the hot air stream and before it got to the correct location on the pad. Overloading of solder would likely result.
For an easy life stick with a soldering iron and vacuum desoldering pump or gun for through hole components.
Also note that the hot air station that you are expecting should be checked for good earth continuity to the case parts and for open air intake slots in the handle (they are often almost completely closed due to poor moulding). Sort these issues out before use.
Fraser
Last Edit: August 26, 2012, 11:31:16 am by Aurora
Logged
If I have helped you please consider a donation :
https://gofund.me/c86b0a2c
ablacon64
Frequent Contributor
Country:
Reply #4 on:
August 26, 2012, 12:29:38 am »
Hot air takes too long when working with through hole components, you're better off with a soldering iron, it's faster, will do less thermal stress on the component.
Logged
amyk
Super Contributor
Reply #5 on:
August 26, 2012, 09:09:32 am »
Hot air is really good for SMD, but as others above said, quite difficult for through-hole. They make
units that have both
for exactly this reason.
Logged
Psi
Super Contributor
Country:
Reply #6 on:
August 26, 2012, 12:00:58 pm »
Hot air is quite handy when trying to desolder through hole components with lots of legs.
Like connectors and dip ICs.
It takes a little while but you can just pull them out once all pins are hot.
It's often faster than trying to remove the solder on every pin with a typical spring desoldering tool which often leaves some solder behind.
Logged
gregoryfenton
Newbie
Country:
Reply #7 on:
August 26, 2012, 02:42:31 pm »
Thanks everyone for your input. It is much appreciated
Logged
T4P
Super Contributor
Country:
Reply #8 on:
August 26, 2012, 03:15:01 pm »
Using hot air to remove is not destructive if done better, if done not so good then the board will most certainly char,
only use hot air for boards you don't mind.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
