Author Topic: Super simple eeprom  (Read 866 times)
Online antennaTopic starter
Super simple eeprom
« on: March 09, 2024, 09:59:00 pm »
I need a very simple memory chip that doesn't use addressing or header stuff, basically a 512 to 1024 bit (or more is ok, I can leave it blank) shift register with non-volatile memory that can be programmed once and repeat the same output stream each time it is triggered.  I can give it a clock and trigger, but I just want it to repeat a very specific serial logic sequence each trigger pulse or power cycle.  Any suggestions?
Thanks!
Edit:  It needs to be tiny and low power, so arduino type solutions are out.
« Last Edit: March 09, 2024, 10:01:32 pm by antenna »
Offline wraper
  • Country: lv
Re: Super simple eeprom
« Reply #1 on: March 09, 2024, 10:10:55 pm »
Just use a cheapest MCU.
The following users thanked this post: antenna
Offline WattsThat
« Reply #2 on: March 10, 2024, 12:44:42 am »
A bare ATtiny-10 is $0.44 and consumes 200ua in active mode. 1.8 to 5.5v supply. That’s not usable?
« Reply #3 on: March 10, 2024, 02:20:43 am »
I didn't realize they came that small, that will work!  Thanks!  I was tempted to pull an audio chip out of one of the dog buttons and trying to make that work but this neat little micro should work too.
Thanks!
Offline AndyBeez
  • Country: nu
« Reply #5 on: March 11, 2024, 08:09:52 pm »
Might not be a fit for your application, but be aware of a family of 3 pin serial EEPROMs which are deployed for configuration and identification. Usually termed 1-wire EEPROMs. For example a 1K device in a transistor TO92 package. Maxim DS2431
https://www.enrgtech.co.uk/product/eeprom/ET18612841/DS2431-
« Reply #6 on: March 12, 2024, 12:47:36 am »
I saw those, but not sure about the header data or if they automatically output the contents directly on power up.  One of the reasons for this is for transmitter identification.  I figured if I had a 10Hz clock oscillator I could program in a call sign as binary and use the output of the chip for OOKing a TX, so that is one of the reasons I didn't want it to need addressing or startup data.  I was hoping to run this on a 3v button cell and have it last a while, but if I need to have a micro to tell the eeprom what to output, then I may as well have the micro do it.  I was just hoping for a simpler, program once, solution.  I get everyones desire to connect a laptop and upload code, it is easy, but even that is far too much for the simple tasks I require it to do.
« Last Edit: March 12, 2024, 12:49:33 am by antenna »
« Reply #7 on: March 12, 2024, 12:53:07 am »
The ideal chip would have a clock pin, a write enable pin, a serial in/out pin, and power pins.  If the write enable is high, it accepts data, if not, it simply outputs the programmed string every time it receives power (or a trigger on another pin).  No header, no address stuff, just the string in memory.
Offline Andy Chee
« Reply #8 on: March 12, 2024, 02:02:22 am »
I would think even an ancient 12F675 microcontroller is capable of your application.  It has a 128-byte data EEPROM for storing your string.  It has an internal oscillator for running the processor.  It has a handful of I/O pins for you to program as input triggers/enables and data output.
The microprocessor code is simple; when it detects a pin going high, it dumps the EEPROM contents out another pin!  And you could probably include a RS232 interface to re-program the EEPROM contents on-the-fly.
There are certainly more capable microcontrollers that would fit the bill.
« Last Edit: March 12, 2024, 02:33:47 am by Andy Chee »
Offline Andree Henkel
« Reply #9 on: March 12, 2024, 09:13:20 am »
The most easy to interface in firmware is SPI
number of pins of interface to µController
1: single wire  ->  2: I2C  ->  3: SPI
difficulty of firmware
SPI -> I2C -> singlewire
Offline Ground_Loop
« Reply #10 on: March 16, 2024, 12:35:31 pm »
Signetics made something in the 70s very similar to what you are asking about. It is a simple one bit shift register with up 1024 bit storage locations.  Clock in the bit stream and continue clocking to recirculate endlessly.  I have a couple that are 256 bit  x 2 for a total of 512 bit storage.  The downside is that they are volatile memory.  If you can keep a power source on them they might work for you.  The part number I have is. Signetics 2527V in 8-pin DIP.  The 2533V is 1024 bit.
« Last Edit: March 16, 2024, 12:45:58 pm by Ground_Loop »
There's no point getting old if you don't have stories.
