Hiya
I've just obtained a valve power supply giving approx 300V DC plus heater output. I want to use this as the supply for a 'valve breadboard' where I will be building valve receivers using subminiature valves such as the DC70 and more normal valves.
I want to supply a range of voltages : 300V, 150V, 100V, 50V depending on the design.
What would be the easiest way to do this - is a simple resistive divider the best choice??
Cheers
Steve
