Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Optocoupler collector-emitter leakage
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Optocoupler collector-emitter leakage (Read 1433 times)
gus789
Contributor
Country:
on:
December 13, 2016, 06:21:19 am »
I am trying to use the circuit in the diagram to a generate 0-10V dimmer signal for a LED driver. The input is a PWM signal from an arduino (0-5V). The problem is that the voltage at the output only goes down to 2.56V minimum. The datasheet for this coupler
http://www.mouser.com/ds/2/427/tcet1100-240288.pdf
says the max collector emitter cut off current is 100nA, which should translate to a negligible drop across the 12kOhm when the coupler is off. Am I missing something obvious or is there something wrong with the circuit?
Thanks!
Logged
mij59
Frequent Contributor
Country:
Re: Optocoupler collector-emitter leakage
Reply #1 on:
December 13, 2016, 06:32:54 am »
Check the collector and emitter connections, they could be reversed.
Logged
Seekonk
Super Contributor
Country:
Reply #2 on:
December 13, 2016, 06:45:06 am »
Something is wrong. I use this circuit as a quick and dirty high side FET driver at my camp with a 300K resistor and there is no noticeable leakage.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
