So I've only ever done through-hole device soldering, and I think I'm... pretty okay at it. But now I'm working on a prototype that uses a couple chips that only come in surface mount packages. I've been watching a lot of videos about hand soldering SMDs and it doesn't look too scary... I guess there has to be a first time for everything.
So two questions; first is related to package selection. I'm leaning towards SOIC... the relatively large 1.27mm pin spacing seems attractive to me as a first timer. Am I on the right line of thinking, or are smaller pin spacing deceptively easier? My other question is around the other chips being used... coincidentally all of the chips have a SOIC package. Should I have everything on the board be SOIC, under the theory that I might get "good" at it (about 8 chips on one board, plan to make 2 prototypes) or should I stick to through-hole for those that come in that package?
RJDog,
I understand the uneasy you are feeling. I am a merely an inexperienced hobbyist and I felt the same when I considered stepping into SMD soldering. The tasks
just appeared to be so damn impossible.
Your questions and reluctance are so similar to my questions and reluctance then. So, allow me to share the story of my venture into SMD... Hopefully, it will help you kick start your venture.
I kicked around the idea of dipping into SMD soldering for what seemed like ages. I watched a few SMD soldering videos and kicked around it some more ever so reluctant because it looked so hard. I found one of my old dead cell phone (StarTac) and started removing parts, and putting them back, and removing them, and putting them back... Did that for may be a couple of weeks (dozen or so 1/2 hour workout), may be more. But the phone was dead before I start, so I never knew if the replacement was correct or if I cooked the part and didn't even know. I did "solder" one IC for so long the pin felt out. So I kick around the idea a while longer.
I have a couple of SMD's I managed to send to electrocution. I need to replace them but they were 1mm pitch and 0.5mm pitch . It look damn near impossible to me.
Finally, I decided to have a go. Dig out that cell phone again, this time, I practice the work flow to cut down the solder-iron contact time. I recall I set a 2 seconds (per pin) target and 5 seconds limit.
After another hour or two of practice, the next day, I decided - time to have a go!
What I was glad I had at hand:
- good flux
- good solder sucking braid (when I applied too much)
- a couple of magnifying glass (4x and 10x loupe)
- a small screw driver (to help position and to hold the part)
- 1mm solder (would have prefer smaller, but that's what I got)
Nothing fancy, I think you probably have everything I had in that list.
The technique I was most glad I learned (from the videos) before I start:
- flux well
- start with a corner pin (so it hold in position), then inspect carefully, then opposite corner, then inspect carefully again, then the rest of the pins, then inspect carefully again.
First shot, 0.5mm pitch (10 pins) VSSOP. Got it on, it works! Second shot, 1mm pitch (6 pins) SOT23-6, got it on, it works. Two successes in the space of an hour or so. I was so pleased by it I wrote this:
https://www.eevblog.com/forum/beginners/some-times-things-work-out-the-way-they-should/It was beginner's luck. As beginner, I was extra careful. After that first day, SMD doesn't scare me anymore. It doesn't look so impossible any more. I have since improved - now SMD is just another chip to me.
Put your doubts in a jar, screw the lid shut and keep your doubts in that jar; then, with your doubts contained, have a go at it. Practice some, practice some more, then start with some cheap IC's... (I started with the ADS1115 which was a $6 chip if I recall... it worked out well but it was not smart.)
Good luck!
By the way, luck tends to favor the well prepared...
