Author Topic: is this a effectively a low and high side switch? or a double high side?  (Read 1108 times)
Offline superwesterTopic starter
  • Country: cl
i was struggling thinking that i needed to control two high side switches.
 but on a second though, as the circuit is powered by a bipolar supply its a good old high and low side half H bridge.
am i right?
sorry if this requires more info from my part, but im assuming it does not.
Offline neko efecktz
Re: is this a effectively a low and high side switch? or a double high side?
« Reply #1 on: February 18, 2018, 08:48:30 pm »
Before anyone can give you a answer, please explain your description high side and low side
Please include a couple of pictures of the switch in question.
Is it an electronic switch or a physical mechanical switch?
BILL.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #2 on: February 18, 2018, 09:08:53 pm »
double post here https://www.eevblog.com/forum/beginners/is-this-a-typical-high-and-low-side-switching-circuit/msg1430243/#msg1430243
i made the same question a while back and, stupidly enough, i didnt post any circuit and i cant erase it :(
there is "Modify" button on top right of each post you can edit your post to include whatever you want to link... fwiw...
The following users thanked this post: superwester
