Author Topic: Sweep function control for MHS5200A function generator using serial monitor  (Read 642 times)
Offline proppaTopic starter
I have used these previous threads to attempt to control the function generator using serial monitor
However, there's no code on how to use sweep function for channel 2? I can only at the moment set channel 1. can anyone help?
https://www.eevblog.com/forum/testgear/mhs-5200a-serial-protocol-reverse-engineered/
Was wondering if someone can point me the right direction or have a solution.
Attached are the protocols.
