I need a circuit that will switch between USB and battery power (USB if available, battery otherwise). The thing is that in this case the battery will be a higher voltage (6.5V-9.5V) than the USB, so the 'normal' method show online doesn't work. I also only have a SPST switch to turn the entire thing on/off (which is connected to VBAT).
I think the circuit below will work, but I'd love another set of eyes, and any input/ideas you guys might have.
