Author Topic: Transformer Help  (Read 947 times)
Offline darthhideousTopic starter
Transformer Help
« on: July 25, 2018, 03:18:51 am »
I need to design and build a transformer which will be used to superimpose an AC signal onto DC power lines (to test a device against ripple). The problem is the transformer needs to operate between 50Hz to 200kHz as well as the secondary having 20A DC current through it. I have minimal knowledge of transformers but my understanding is that any DC current flowing through the secondary will cause the core to saturate so to alleviate this introduce an air gap. I'm a bit lost with how you incorporate an air gap into calculations. I was going to go with a ferrite core but still have not been able to determine the size or cut types. Does anyone have any suggestions?
Offline JS
  • Country: ar
Re: Transformer Help
« Reply #1 on: July 25, 2018, 04:46:07 am »
Can't you introduce the ripple in some other way? Like the power control of the DC power source? How much signal do you need to introduce to the system?
For big dc currents you need big gaps wich makes harder to keep the transformer working as such in a wide freq range.
To deal with DC on a coil you could introduce the opposed force to other coil so they cancel out, that could be the same current same ammount of turns or anything as long as you keep I×N constant. You could use the coil where you introduce the signal or a dedicated coil. It doesn't need to be a perfect match, just enough to keep the core without saturation, you are likely to need some sort of feedback or at least current sensing on the output. To make things easier you could use a gapped transformer and a reverse current coil so dc tolerance is higher but transformer has better properties than with a bigger gap.
JS
If I don't know how it works, I prefer not to turn it on.
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: July 25, 2018, 06:18:17 pm »
What impedance?
The usual method is a LISN, or CDN, or bias tee: a series inductor isolates the DC supply from the AC signal and EUT, and a series coupling capacitor isolates EUT voltage from the signal.
If the EUT should see an impedance of 50Ω, then this is adequate.  If it's a much lower impedance -- as might be the case for a related kind of test, like power supply upset, or power interruption attack (see ChipWhisperer and such), then consider merely using a resistor divider, and much more signal power, to get the desired supply impedance and signal input.  Upside to resistor divider is, you get attenuation for free, meaning your amplifier doesn't see a nasty SWR, regardless of what the EUT impedance is.  Downside is, you can end up needing 10 or 100W of RF, very easily...
At some point, attenuation gets ridiculous, and you should use a transformer instead.  Or a combination of attenuators and transformers, as suits the system, for frequency response, SWR, available power, required stimulus, and so on.  Just a compromise between these, however it works out best.
An astute observer may note: "Ah, but you just suggested using an inductor, coupled to a transformer -- can't that just be reduced to a transformer?"
Indeed it can.  The coupled configuration is called "parafeed" (in audiophile circles, at least).  One advantage is using all off the shelf components: no worry about DC in the transformer.  If you're winding it yourself, yes, you can gap the core to get the required DC handling, or add the primary winding to the inductor just as well; but this is undesirable for RF response, because you need a much longer winding to get the same impedance.  Winding length corresponds directly to the HF cutoff point.
For modest bandwidths (say, 2-3 decades), this will be fine.  Example (again from audiophilery), vacuum tube output transformers (single ended output type) typically satisfy the 20-20kHz frequency range, while handling an equivalent amount of DC as signal (i.e., typical of a class A amplifier).  Using a much smaller winding on gapped ferrite, say, you can easily recreate this experience, but at, say, 10kHz to 10MHz.
Note that exotic materials don't have any benefit here: nanocrystalline cores, or high-mu ferrite, are just thrown away because of the air gap.  Powdered iron is quite reasonable, but don't go too low on permeability.  Probably 30-100 mu is best, so as to keep the winding length on the short side, without requiring an excessively large core.
As for completely different methods entirely: you may well find it's better to build, what is essentially an audio amplifier, or regulated power supply, that includes your desired bandwidth.  50Hz is too low for practical ferrite inductors, and 200kHz is too high for practical laminated-iron inductors.  (So obviously, stack both to make a wideband bias tee -- this requires some finagling, however.)  The nearly 4-decade range is quite reasonable for nanocrystalline-core transformers, but you may find it's easier to avoid going that route, and solving it with transistors instead, even despite the high current.
Seven Transistor Labs, LLC
« Reply #3 on: July 31, 2018, 11:33:45 pm »
Need an impedance of 0.5ohm. My friend went down the amplifier path and could not get it to work so suggested I looked at transformers.
