Author Topic: Instrumentation Amplifier exercise  (Read 1486 times)
Offline alex123Topic starter
  • Country: cl
« on: May 12, 2020, 12:39:54 am »
If the site's Ad gain is 1000 (times). Determine the resistive components of the circuit.
I came to the conclusion that vo / (V1-V2) = (R3 / R2) (1+ {2R1 / Rgain}) Take the traditional 3-opamp instrumentation amplifier, keep in mind that operational amplifier 1 is inverted
« Last Edit: May 12, 2020, 09:05:03 pm by alex123 »
Offline gbaddeley
Re: instrumental amplifier exercise
« Reply #1 on: May 12, 2020, 03:04:30 am »
FYI , it is Instrumentation, not Instrumental (pertains to music)
Glenn
Offline Jwillis
« Reply #2 on: May 12, 2020, 03:51:05 am »
G= R3/R2 (1+2R1/Rgain)
R3=100K
R2=10K
R1=9k9
Rgain=100
Online magic
« Reply #3 on: May 12, 2020, 04:17:17 am »
Indeed, this is some nonsense circuit with positive feedback. A1 output will randomly saturate into either of its supply voltages. I suppose that has to be a mistake.
The following users thanked this post: alex123
Offline Circlotron
« Reply #4 on: May 12, 2020, 05:19:41 am »
The upper opamp is wrong. Various websites have copied and pasted without looking closely. Most have it right though.
https://www.google.com.au/search?q=3+op+amp+instrumentation+amplifier&source=lnms&tbm=isch&sa=X&ved=2ahUKEwihyduTya3pAhXZHDQIHZK_A8MQ_AUoAXoECBAQAw&biw=1264&
bih=951
Edit -> seems the same set of images don't come up every single search...
« Last Edit: May 12, 2020, 05:21:59 am by Circlotron »
Offline Jwillis
« Reply #5 on: May 12, 2020, 05:33:53 am »
bih=951
Your right . Shouldn't both inputs be non-inverting ? So my calculations would be wrong.
Offline anvoice
« Reply #6 on: May 12, 2020, 06:22:55 am »
I had a class in uni called "Instrumental Chemistry". We played 0 music.
Offline chris_leyson
  • Country: wales
Re: Instrumentation Amplifier exercise
« Reply #8 on: May 13, 2020, 07:44:53 am »
Reminded me of this:-
Offline Jwillis
« Reply #9 on: May 14, 2020, 02:23:11 am »
https://www.elprocus.com/what-is-an-instrumentation-amplifier-circuit-diagram-advantages-and-applications/
If you read the paragraph   .   Instrumentation Amplifier using Op Amp
"The instrumentation amplifier using op-amp circuit is shown below. The op-amps 1 & 2 are non-inverting amplifiers and op-amp 3 is a difference amplifier. These three op-amps together, form an instrumentation amplifier. Instrumentation amplifier’s final output Vout is the amplified difference of the input signals applied to the input terminals of op-amp 3.Let the outputs of op-amp 1 and op-amp 2 be Vo1 and Vo2 respectively."
This leads me to believe that the circuit is drawn wrong on that web sight.  Op amps 1 and 2 must be non-inverting.
