I posted just a minute ago in another post about introducing other metals into an etchant solution. I feel so strongly about this that I had to make it a topic so maybe more people see it.
The very first thing you should do before using any etchant is to read up on any pitfalls in the safety or health area. Muriatic acid and hydrogen peroxide is a popular etchant and is one I use myself, it works fast and is cheap and I have used it for years. The problem with this etchant are a couple different things:
It will burn skin if you leave it in on the skin for more than a second or two.
Fumes produced are dangerous if inhaled directly.
It is very dangerous if you are not careful about what you combine with it.
It will damage plumbing , metal sinks , including stainless steel , making them rust.
So what can you do to prevent damage or harm ?
First , wear gloves. I don't care how uncomfortable they are, or how safe you think you are, use gloves.
Second , eye protection. I know many will say that is overkill and at first I thought, I am careful enough, I am not going to get any on my face. Until the day when I was using one of those foam brushes to rub off some copper on a board area and the brush when hitting the edge of the board, flipped up and sprayed dots of etchant on my arms and face. If it had gotten in my eyes I could have had some serious issues.
Third , have a carton of baking soda near the work area. Baking soda can neutralize any spills of the acid almost immediately. I once had some etchant splatter onto my arm, it started burning in a few seconds, baking soda neutralized it immediately . Water will work as well but it takes longer because unless you put the exposed area under running water you are just diluting the acid.
Fourth - know your etchant !
The muriatic+peroxide etchant is popular, its fast, and easily available, but I doubt many realize how dangerous it can be.
Introducing other metals besides copper is a big NO with this stuff. Aluminum in the solution will get so hot as to boil the etchant and produce hydrogen gas which it can then ignite. Acetone , something many use to clean boards, becomes an explosive if mixed with the etchant.
Fifth - disposal . Etchant should never be poured into the sink, dumped outside, or placed in the trash. I do not use new etchant with each board, instead I have used the same batch of etchant for the past year and have done 30 or so boards in that same batch. The peroxide added will off gas leaving the muriatic acid and that contains a lot of water as does the peroxide. If you can find a safe place to leave your etchant uncovered, the water will evaporate leaving a very strong acid solution. To re-use one only needs to increase the peroxide and sometimes a cap full of acid. To dispose of you can leave the etchant to evaporate in a safe area. The result will be crystals of the copper that you removed from the boards. You can easily place those in a small container and take them to wherever you dispose of toxic materials in your area.
I haven't covered ferric chloride because it isn't as available as it once was. Most of the above applies to ferric chloride except it doesn't harm skin as much on contact and the aluminum reaction doesn't occur.
Feel free to correct or add, be safe !
