it's a 120v motor rated for 6 rpm.
it will generate AC, at a pretty high voltage, put your multimeter on it in ac, stick it in a vice/vise and SLOWLY spin the shaft with your hand, and then with a drill to see what kind of voltage you get, you might be surprised.
