Author Topic: TAB bonding machine  (Read 2869 times)
Offline JaneTopic starter
TAB bonding machine
« on: August 04, 2015, 10:32:21 am »
Does anyone know what kind of heating  pulse TAB bonding machines use?
If induction heating or resist or different?
Thank you
Offline Fraser
Re: TAB bonding machine
« Reply #1 on: August 04, 2015, 11:13:24 am »
Inter metal junction Resistance.
I have such a unit for battery tab welding.
Aurora
Offline amyk
« Reply #2 on: August 04, 2015, 12:11:15 pm »
Aurora
I think you've confused battery tabs with Tape Automated Bonding as commonly used for LCD controller mounting. More discussion here:
https://www.eevblog.com/forum/chat/diy-hotbar-bonding-machine/
Offline fcb
    • Electron Plus
« Reply #3 on: August 04, 2015, 12:37:16 pm »
Another name is: "hot bar", you might able to glean more from that search term.
Offline EEVblog
« Reply #4 on: August 04, 2015, 12:43:32 pm »
Yes, I know them as "hot bar" machines.
« Reply #5 on: August 04, 2015, 02:02:45 pm »
Yes, I would like know what kind of  heating is used  for hot bar machine that is used for  LCD controller mounting, flex mounting to PCB  etc.
Thanks
Online Shock
« Reply #6 on: August 04, 2015, 03:07:22 pm »
Thanks
A quick look showed one brand as using a thermode, and hot air probably to keep surface temp consistent. I've seen a video showing the main heating at 200C with 2.5Mpa pressure for 25s.
« Reply #7 on: August 05, 2015, 09:27:54 am »
@Shock:Do you have a link to the video?
