My almighty Cheb2ords! I bow to thee and humbly implore thy gracious wisdom...
So I'm following Dave's YouTube tutorial on how to "Bode plot" on an oscilloscope using a function generator:
So if I understand this correctly:
The function generator sends out of the main output a frequency sweep in 1 second. It also sends out a 1 Hz square wave via the sync output, which is aligned with the main output sweep.
You then use Ch1 to view the frequency response, and Ch2 to trigger off the sync square wave.
So over a period of one second, (and if I set my triggers right) I should only see one period of the 1Hz square wave, and only one frequency sweep.
Now my problem: The function generator is not sending out a 1 Hz square wave even though the sweep time is 1 second. The square sync wave is "sweeping" along with the main output wave. I looked in the manual and it doesn't say anything about changing the frequency of the sync wave.
I've seen other function generators do this, so my question is, am I just not setting up the function generator correctly? Or is the function generator not capable? (It is an older HP).
HP3325B Operating Manual:
http://exodus.poly.edu/~kurt/manuals/manuals/HP%20Agilent/HP%203325B%20Operating.pdf
