I'm working on a MiroKORG digital synthesizer, and the only problem left is that the TECHNO rotary switch selection, the Program 2 and Bank A/B tact switches do not work. Pressing the tact switch, or rotating the switch to TECHNO, has no effect.
Looking at the
schematics (page 9), you can see that the 2nd pole (labeled #3) of the BANK SELECT rotary switch (SW2) is on the same line as the Bank Select A/B tact switch (SW5), and Program 2 (SW12). I suspect the second pole on SW3 and SW8 (labeled #3) also don't work, I haven't tested them specifically.
I looked at the traces and there's strong continuity from pole 2 of SW8 all the way to pin 69 of IC18 (on page 6 of the service manual, following T1).
D14 and D20 test fine (page 9), C186 and L30 (page 6) also seem fine.
I've replaced the tact switches and cleaned the rotary switches contacts before realizing that wasn't the problem. All switches test fine.
And that's where I'm lost.
If it was a problem with the multiplexer (IC22, page 9) I would expect more than those buttons to give unexpected results, but I admittedly don't know what I'm talking about (that's why I'm in Beginner)
But what else could it be? a logic failure in IC18 (CPU)?
What should be my next troubleshooting step, swap the multiplexer?
Thanks!
