When the fault shows, tap the board with the insulated end of a screwdriver. If the voltage fluctuates then you have a dry joint and need to examine the relevant solder connections with a magnifying glass.
If the voltage regulator is getting hot, then suspect an overload or short circuit somewhere.
Check all the related electrolytic capacitors for any sign of bulges or deformation of the casing. Electrolytic capacitors are one of the least reliable components, especially cheap ones.
