Author Topic: Gyro signal conditioning 1.5v +- 1v to 0-10V  (Read 2070 times)
Offline ArowanaTopic starter
« on: November 19, 2013, 02:14:15 pm »
Hello, I'm trying to read a analog gyroscope using a canbus io-module. The gyro ST LPY410AL outputs a 1.5 +- 1V voltage for the angular rate and a 1.5v reference voltage. The IO module has a 0-10v 10bit adc and provides a 10v reference voltage.
I have designed a amplifier circuit that will take the gyro output and convert it to a 0-10v signal.
e.g. Vout = 0.5*10v_ref + (V_in-gyro_ref) * 5
I'm a programmer by trade so the digital side of things is no problem, but this is my first opamp design.
What I would like to know is:
Is my design sound?
What opamp would you recommend?
The bandwidth is very low, the gyro is measuring the turnrate of a heavy vehicle, so its tens of herts only. The iomodule samples at 40hz.
I have attached a shematic of the circuit and a spice diagram that I used for simulation
Any help appreciated.
Re: Gyro signal conditioning 1.5v +- 1v to 0-10V
« Reply #1 on: November 25, 2013, 11:02:24 am »
Anyone?  :-\
Offline fcb
    • Electron Plus
« Reply #2 on: November 25, 2013, 11:16:20 am »
Looks like a diff-amp job and thats what you've used. I haven't got time to work through the math at the moment.
However I would probably do it slightly.  I would use a differential amp firstly on the gyroout and gyroref to give you say +/-5v w.r.t. 0V signal, then a second differential amp using the adc reference to take you to 0-10v.
Remember you are only compensating for the 0g posistion by using the reference, scaling is upto your software.
